RCU Forums - View Single Post - Could I Put Monokote in my HUGE gaps to lower flutter or eliminate it??
Old 01-23-2004 | 10:36 PM
iflynething
Default RE: Could I Put Monokote in my HUGE gaps to lower flutter or eliminate it??
So, if I understand correctly, cut everything out flush w/ control surfaces and stablizers. Then take the joiner out and throw it away. Get the same size wire or the old joiner and make it longer and drill new holes that are STRAIT and into the elevators. Then, get pinned hinge points, drill hole for 3 hinges on each side and put them in, epoxy and go fly.......If I put something that was not right, please correct me..I WANT TO DO THIS RIGHT...THANKS EVERYONE FOR ALOT OF GREAT ADVICE......!!!!!!!!!!!!
