ORIGINAL: warren
Interesting; my 9C has to be turned on...
If the 9C adapter is properly designed, there is no need to use the Tx switch to turn it on. The Tx will be powered up and the RF circuit will be disabled upon plugging in the square connector. If you have to turn the Tx switch on, your RF circuit is probably active and you will need to remove the module.
