RCU Forums - View Single Post - Sig Four Star 40 ARF
Old 01-24-2004 | 02:52 PM
nitro wing
Default RE: Sig Four Star 40 ARF
ORIGINAL: FHHuber
The 4*40 is not meant t be fast... propping it for speed is an error. (and a reason for the negative comments you sometimes see about it)
Use the longest, lowest pitch prop you can swing properly with your engine (and not hit the ground durring takeoff) a 11X4 on a .40 is a whole new world in aerobatcs with the 4*40 compared to that 10X6 you think you should use. (and top speed is actually higher because of more PULL with the longer prop) Also... it slows for landings MUCH better with the lower pitch.
Yes you are right for the set up...but some people want more speed to play with sometimes and in my case I experimentd with different props and got awesome speed put of it.I flew it really hard for 3 seasons.I built it myself and I actually tried to overstress it a number of times.didn't work...If the ARF is built well then it could be horsed around a lot.It does fly best however with reasonable settings
