Thanks all!
I got a sweet deal on the OS 46 so that is what I will put in her. Have no intentions to try and make it scream. Just wanted the plane for all of the stable maneuvers and slow speed forgivings the airframe is reputed to have.
Plus I have the older kit version that I bought with a low run time OS 40. Should be able to have a ton of fun with the two of them.
Was just in my garage putting away some stuff for the wife and looked closely at the wings side by side and noticed their is a major diff in the ailerons. The ARF has tapered ones that are much broader at the wing root and narrower at the wing tip than does my older kit version. Basically a rectangle (old) vs a trapazoidal shape (ARF).
Anyone know if this is the same config newer four star kits are using also? Just curious.
GrumpE
