RCU Forums - View Single Post - Electrified Partner
Old 01-26-2004 | 10:30 AM
  #56
robhoneycutt
Default RE: RE: Electrified Partner ...plus
Congratulations on your first flight!
It's easy to get more speed if you need to, just play with the prop pitch, you might have to decrease the diameter in the process to keep the amps down.
Did you measure your static amps WOT? Have you recharged your batteries to see how many mah you put back into them? Pictures!
Rob
