RE: mt2 compression problem
the best way ive found to prime mine is fill the tank hold the lid up and press on the pressure line where it goes in the tank pull the lid back till it dont want to move and let it slam that will try to compress the fuel but the fuel will run up the line to the carb instead it uses the path of least resistance
