RE: Super duration glow?
Maybe you could use a Perry V30 pump/ regulator so you can use as big a tank as you want w/o having the fuel mix. change on you? You can also put the tank over the C.G. and not have to worry about that problem either. You do need a 2 needle type carb. for that though.
