RE: Super duration glow?
Yeah Frank, you usually tap right in the center of the backplate, making sure the fitting is flush on the inside. Other locations can be thru the mt. lug (don't think I'd do it that way) or use a special backplate (hollow) bolt usually in the upper left bolt hole.
