RCU Forums - View Single Post - My prop don't work
Old 05-29-2002 | 11:03 PM
T. Bob's Avatar
T. Bob
My Feedback: (9)
Default My prop don't work
Michael
This is in an CG Ultimate so I rarely have it at full throttle it's usually at about half. As for tuning the engine, I burn 20/20 fuel so at around 2 - 2 1/4 turns you get a pretty good smoke stream from the exhaust and the transition is good. Then I hold up the plane at full throttle to check if it's lean and off she goes. I will also check the RPM they are usally around 9200. As for low end I never touch it.
Thanks for you input.
