Originally posted by Chris 540
>>Yes this is what will usually happen, but what if you have a glitch and the throttle goes full open for a few seconds?? The plane isn't going to just plop down right there.
If the pilot has a clue and uses PCM, thier fail safe will be set for a low idle...therefore a radio hit would make the plane fall down.
Like what was stated, it's a what if and it can go on forever. So the plane has it's under side to the spectators and you have the PCM set for level flight, BOOM right into the crowd, but what if the pilot is using PPM? Now usually a glitch doesn't give much of warning, been there to many times, and this can be argued in way to many ways.
