RCU Forums - View Single Post - mt2 compression problem
Old 01-28-2004 | 01:42 PM
  #32
mecky33's Avatar
mecky33
Default RE: mt2 compression problem
When you took the head off, did you make sure that the head gasket was there? The head gasket is very thin metal and you may not have gotten that back in place. without a head gasket, the head will not get a good seal and it will leak. You may be able to get a head gasket at your LHS. If not, you can get one from www.ehobbies.com
