RE: Real Flight and xp
G2 is working fine on XP here and at my buddy's place. Both using the USB controller.
I have had some problems with XP and the joystick port... seems you need to go into control panel and select whatever you want as primary controller every time you switch... it won't let you use the RF controller, then joystick, then steering wheel without making the change.
