RCU Forums - View Single Post - In a loop, the plane rotates to the right.
Old 05-31-2002 | 12:43 PM
MinnFlyer's Avatar
MinnFlyer
Default In a loop, the plane rotates to the right.
A lateral balance problem WILL make a plane behave like that.
Another cause could be your elevators. Does each side of the Elev have it's own push rod, or are the two sides linked with a wire joiner? What can happen is that one Elev deflects more than the other causing them to act like Ailerons.
