RCU Forums - View Single Post - In a loop, the plane rotates to the right.
Old 05-31-2002 | 01:23 PM
Dave Barrow-RCU
Default In a loop, the plane rotates to the right.
Check the elevator halves as Mike suggested. If they are ok, it could be that you have over-corrected for level flight with ailerons. Trim the rudder for a straight loop, then adjust the ailerons for level flight.
