RCU Forums - View Single Post - HELP! Can't get enough elevator throw on my CA 27%
Old 02-02-2004 | 06:32 PM
mglavin
My Feedback: (31)
Default RE: HELP! Can't get enough elevator throw on my CA 27%
ORIGINAL: desertpig
ORIGINAL: tommy s
The connecting point at the elevator control horn should be right on the
hinge line not 1.5 inches from it.
tommy s
Many large scale planes use top hinging, similar to what a real airplane uses, which makes putting the control horn on the hinge line impossible. This drawing demonstrates...
DP
True, but you can use an offset adapter or horn such as the Nelson hardware which is limited to 3/8" or so and then there is the Dubro control arm which is much longer...
