RCU Forums - View Single Post - Outside diameter of ASP radial?
Old 02-03-2004 | 04:43 PM
William Robison
Default RE: Outside diameter of ASP radial?
RPM:
If you have the 3.0 cubic inch ASP radial, all dimensions are the same as the 5R300 OS radial. If you have the 4.0 ci engine I think it's just a bore difference with the same stroke and outside diameter, but I'm not certain.
Hope this helps, at least a little bit.
Bill.
