Outside diameter of ASP radial?
AZ
Can anyone give me this dimension? I have emailed Just engines.com and doesent seem to want to talk much.
Other dimensions would be great too.
Rick
Rick
RPM:
If you have the 3.0 cubic inch ASP radial, all dimensions are the same as the 5R300 OS radial. If you have the 4.0 ci engine I think it's just a bore difference with the same stroke and outside diameter, but I'm not certain.
Hope this helps, at least a little bit.
Bill.
Bill.
