RE: Sportsman Waco .60 Arf
I did not use the original hardware, I used 4-40 slave rods and i have moved the control horns on both top and bottom surfaces. The one on the top is about 1/4 inch from the trailing edge, the one on the bottom is about 1/4 inch from the the hinge line. This gives me more throw in one direction than the other on the top wing. I did take the plane out this weekend and fly it. Overall it flew great, had to add down trim to the elevator and i need more aileron throw. I did have some flutter when coming out of a turn at 3/4 throttle or higher. I think this is because of the wire between both elevator halves, When i built this plane i moved the servos for the rudder and the Elevator to the outside, I am going to add another servo for the other elevator half.
Can anyone help me with the original problem with the servos on the Ailerons binding because of the slave rods.
Craig
