RCU Forums - View Single Post - Capiche 50
Thread: Capiche 50
Old 02-04-2004 | 12:45 PM
  #2476
Sprink's Avatar
Sprink
Default RE: Capiche 50
ORIGINAL: AsM
i covered the tail b4 i glued it in, is this betta than after like eddy did?
No. I normally do that, but there is not a large amount of area for the glue to stick to in the C50, so I covered afterwards. You also have to beware that if you cover the tail as a whole, then cut out the centre section, you will weaken the wood as you will be cutting into it.
