V-max,
Yes everything works, I was just afraid the airflow would peel back the covering material on the LE that is a little damaged. The only thing that I haven't gotten to work yet is the on-board glow starter. I'm charging the battery, but since it is linked with the throttle electronically through the ignition I also need the TX to work. Unfortunately the TX battery contacts have gone bad, and I'm in the process of fixing them with someones suggestion of replacing the existing contacts with the futaba J connectors. The TX is one of the older 8 channels with the battery that has the connectors like a 9v battery. Thanks for the advice, but I don't want to buy anymore planes until I see if I can get some of the ones I already have flying. I'm working on my Tele right now also, and then it's on to the 1/3 Cub with the G62.
