Hi ZimboRaider, on the Eagle the fuel tank end with the line openings should face the engine,about the only time this set up changes is when using a pusher engine set up,the eagle is a tractor set up, meaning pulling the plane,having the lines at the wrong end can cause the fuel line not to pick up all the fuel as gravity carries it away from the pick up clunk.
