Get a clear canopy, then you can add a pilot. Most of uspeople on the main C50 thread say that if you buy the carbon cowl you really need to make the fron of the plane black to blend it in (like luke 3D's). Ive got the GRP and i will spray it to my chosen colour scheme.
Do I need control horns?
As the chamfer on the ailerons is allot id get the L&R horsn for the ailerons
C50 Throttle control run?
This comes with either the fuel or the base acceories, in outer words no, you dont need it
Nylon bolts, nuts listed for C50?
No, in the base accesories
9 oz. fuel tank $2.55
Get the fuel set, this comes with tank, fuel tubeig and filter and possibly the throttle linkage
3 mm metal clevises $4.37
They come with the direct drive pack.
Ian
