RE: Ordering Capiche 50
Bill
The Fuel Tank, tubing filter etc, horns, throttle run, clevises etc etc all comes in the base accessories pack, which is included with any of the kits.
If you look at the IH price list the over and above the kit you just pick from the yellow highlighted items...
Basically for a full lot you would take
Kit - you choose the spec
Pushrod set - you choose the 2 or 3mm set
Wheel Set - lightweight sponge wheels, steerable tail wheel assy, main wheel axles with collets etc.
Thats it complete, unless you want to add things like props, spinners, etc.
You should not take any tax off the IH prices, they are exclulsive of tax already, but I dont know how this will work out as far as carbon copy is concerned - presumably since its export there will be no UK tax added so the prices should be same as IH.
When I talked Cowls, I was basically saying that the GRP item is worth the upgrade. The ABS ones are fine for a while but like all things ABS, unless you really look after it they eventually start to crack.
