401 clarification
it says in the directions under direction check.
" if the rudder servo moves to the left when the nose of the heli moves to the right then the gyro direction is correct.
I have a boom mounted sideways servo and the linkage is on top of the radius. when I give left rudder the arm pushes towards the tail. looking at the servo from across the heli and at the arm infront of the servo ( head on) the arm moves counter clockwisewith the linkage at the top. I think this is what they mean when they say "if the servo moves left"
am I right?
and to confirm then this setup, should be in normal mode NOT in reverse?
today I broke in the enigne and let it rpm a little on the ground with out lifting it up.
will this gyro work indoors?
thanks
Paul
