RCU Forums - View Single Post - 401 clarification
Old 02-08-2004 | 07:42 AM
siclick33
Default RE: 401 clarification
Gyro can be mounted in either position. Under the canopy is good as it protects the gyro against dirt and oil ingress. If you move the gyro ALWAYS re-check the reverse. Moving the gyro from in front of the main mast to behind it or vice versa will affect the gyro direction.
