RCU Forums - View Single Post - Capiche 50
Thread: Capiche 50
Old 02-09-2004 | 10:19 AM
  #2487
Archie
Default RE: Capiche 50
ASM
If bits cracked off I can only assume you were being a bit heavy handed / rushing !?
I use a dremel with a small drill bit to run a load of holes along the line to cut, then use the drill to connect the dots, then a sanding end to smoothen it up and Ive never had any trouble...
Not likely to be the quality of the cowl in question I would say..
We just had some great feedback in from Ireland on the C50 ! Took a Madness head on apparently and matched performance !? Interesting !
