RCU Forums - View Single Post - Throttle does not work on helli's On AFP
Old 02-09-2004 | 01:14 PM
raptorheli2
Default RE: Throttle does not work on helli's On AFP
to use the auto you must have another channel like 5 in use. otherwise when you close the throttle the engine will close, then as you come into land and want to flair out the engine will again kick in meaning you are not autoing.
cheers
