RCU Forums - View Single Post - Gas powered Sukhoi????
Old 07-05-2002 | 09:14 PM
  #38
2lo
Default plugin wing
morepower
after cutting the wing back in half again, making a sander to fit the spar channel and sand out the left over epoxy and do some final finish in the wing for a good fit with the spar, I used the wing saddle to retain the incidence. after useing the left over light plie to build the mount area and used the wing retainer mount help in building locking tabs for the other pieces for the wing mount. I also went ahead and built the landing gear mount also. I just used all the existing lips inside the fuse to help strengthen and retain the fixtures.
