RE: routing antenna
I guess that would be more like spagetti than a pushrod tube, all coiled up. I wasn't not able to push the tube from the "inside" out. So I had to run the wire through the pushrod tube after it was already installed in the plane. The tube did bend enough to allow me to run the tube all the way to the receiver. Then I pushed fishing wire through the tube and tied to the very end of the antenna and pulled it through.
