RE: Your Idea's on Hitec bad Wrap
If they are set up properly, and this is a big "if", you will be very happy. Go to the "down on the deck" website and check out the programming video. If you are going to gang them together, I think this step is a must. If you are going to use them independent on each control surface you should be fine.
