RE: AFP - Will Not Recogize Transmitter
Hi
I have just installed AFP pro on a friends PC for him, running Xp. He is also using a JR tx. The only problem I had was the TX was not in PPM mode to start with. I changed that to PPM and have had no problems ever since.
The calibration was no problem and I reversed the servo channels to match the correct movements, just as in a normal plane. It works great. We spent 2 hours last night trying to hover the G202 and the extra.
My suggestion is to check the bios on your PC, make sure that the serial port is set to a specific address, such as 3f8 and IRQ4.
There is also an update on their website which might help, I have not installed it yet, so that is not the issue for getting to work in this case, but it may help you.
