RE: Down-right thrust mod on Slow Stick
After flying the SS with stock straight mounting the first dozen times or so, it's so easy to get used to applying a correct amount of elevator and rudder input required under WOT, I don't see the point of spending +$6 on a mount, imo. I've also tried using 2 mixes (multipoint) on my radio to do elevator/rudder correction coupled with the throttle channel, it works quite well but mainly it's an exercise in programming a computer radio. You can also cut a block of wood with a couple degree kinked line and clamp the Al tube along the line to creat a proper bend. Still, the best I've found is to just fly the plane as it is, hundered's of flights and it hasn't bothered me a bit.
