on mine i just had max everything really.. The hype is one of those models that can make use of flapperons and spoilerons, however, i rarely use flapperons at all... on the hype I had about 40 deg aileron mixed with about 75 deg elevator deflection.. this seemed to be the balance that I like, however, I think everybody's different.
Generally with flaps and spoilerons IF you go for the same deflection on the ailerons as the elevator, then take about 15 degrees out of the ailerons, you should be in safe territory, just increase it as you like.
For hovering and torque rolling I found the hype to have better tail response if using flapperons.
Thanks for your comments too
Regards. Nathan.
