how to set new engine
I'm putting together a Skyward 60 Trainer with a K&B 61 engine. I've noticed some engines are canted to the right in some planes and assume it is to counter act the thrust of the motor. Since the stringers in the engine compartment are not pre drilled I'm wondering should I set the motor at an angle and if so how many degrees? Or should I just put it in straight?
Horseman
