rdcracer, yea, we talked. you were telling me about that and the fact that I got your wing tube
AS far as the crash, everything works here. I have run the packs down and charged them and run them down again cycling the servos with my 9C. From what I was told at the field, the elevators deflected "DOWN" when I took off.
It was a controlled maneuver and I would like to have seen a list of pilots on Channel 38.
At first I thought it went into failsafe but if it did, the throttle would have went to idle. I do have to admit, that I store my transmitter with the throttle at idle. If someone turned theirs on, it should go to idle or some setting different than mine. Unless the controls are reversed then their idle would be my WOT.
