RCU Forums - View Single Post - Designing or modifying plans using CAD
Old 02-11-2004 | 12:50 PM
DICKEYBIRD's Avatar
DICKEYBIRD
Default RE: Designing or modifying plans using CAD
Just choose the "Generate DXF" option and C/Foil will save whatever you have up on your screen: wing planview, lofted set of ribs, foam cutting template, leading edge template set or an individual rib. I use it all the time....what a great program! You open the .dxf file in your CAD program and copy/paste the needed rib or whatever into your drawing.
