RE: Engine Probs
i am thinking that it is possible you are running too lean. have you checked the temps or tried richening up the needles? this is normally a problem associated with an over lean condition of the HSN, although in your case it may be something different due to it being stored so long. you may also want to try replacing all the fuel line.
