RCU Forums - View Single Post - CA Model Eclipse building tips
Old 02-12-2004 | 07:40 AM
swk551
Default RE: CA Model Eclipse building tips
I moved the stab back to the 2.5" reference dimension to match the Smaragd. I do not think this will have much effect on the flight characteristics. So you can leave the stab in the current location relative to the rudder post. I do believe my thrust line dimension to the bottom of the fuse and the vertical offset of the stab relative to the wing and thrust line is more important. I am trying reduce roll couple with rudder.
Good luck,
Steve
