RE: Problems!!! Screws can't get out!
hi
if you are using nylon bolts and you can partially unscrew enough to bet under the head of the screw and cut the head off with a cut off wheel you can remove the wing and the remainder of the bolts and start anew.
hope this helps
good flying
joe
