Runway is correct.
The MVVS just isn't gonna play well on anything over 5% nitro unless you start shimming
the head.
FAI and Low nitro fuels aren't terribly common in HS's, but most all of the leading fuel mfrs
offer the product, and your dealer will have no problem ordering a case (usually 4 gals) for you.
You'll be surprised that you can get a case of Omega FAI (for example) for under $40.00. That's
a good bit of flying!
Good Luck!
PS: You might be close enough...why not call Stan at S&W in Eastern PA and check him out? His FAI
fuel is <$7.00/gal.
www.s-whobby.com
