RE: Balsa sheeted foam wings vs regular type ?
The foam core wings are bit heavier... but they are stiffer, stronger and will have a more accurate airfoil over the entire span.
There are trade-offs and the main one here is weight for strength. The foam filled sheet structure is rock solid. It is fairly rare to see a foam core wing fold up in flight. (unless you are REALLY abusing the model...)
