RCU Forums - View Single Post - Seagull Models Extra 300S .60 Questions
Old 02-14-2004 | 10:23 PM
  #53
glowplug
Default RE: RE: Seagull Models <span class=
Rob,
I got to maiden it today!!!
SuperStick was right on the money with his flight report!! The aerobatic capabilities COMPLETELY surprised me! With the relatively small control surfaces, I thought the plane would be kind of calm.....not so! This thing snap rolled like a blur, and I was able to get it halfway through a knife-edge loop. Spins are VERY tight (I didn't try any flat spins yet). It is definitely sensitive on the sticks......and it WILL snap (quickly) with too much elevator....be easy on the stick. I didn't notice sluggishness with the ailerons, but I did have the throws set higher then recommended. The GMS .76 pulled it very well....I mostly flew at 1/2 throttle.
I think I'll be changing mine too........I flew the plane for only about 6 minutes.....than ran the plane on the ground for only about 4 more, and the tank was empty.....I think I'll install a flew tank also.
I did build mine with the fuel tube......and my filler line comes out at the bottom of my cowl.....since I don't like some of the problems that can't come along with remote fuelers, I use the DuBro "Fill-It" Fuel system. It's basically a set of fuel line plugs for the 3rd line......astro, the line must be plugged or else the fuel would come out....and you wouldn't have fuel pressure either. I'm looking forward to flying it again!
