RE: RE: Seagull Models <span class=
Congrats on the first flight! I'm glad to see all went well... It sounds like you could make good use of the larger tank!
What size prop are you turning?? I am going to be using a 13X6. I am also trying to go with a single elevator servo..... Not sure if its the right way to go, but it saves a bit on room, weight, and screwing around with the left and right throw setup....
If it doesnt work....I guess I'll be the first to know! I will lust solder the 2 rods together at the servo and go from there.
Thanks for the info on the fuel deal! I thought it seemed a little odd...... My first flight would have been a wee bit shorter than I expected!
By the way.... I know the CG is 4cm from the lead at the tip.....Has anyone transfered that mark to the side of the fuse?????
I like to use my CG machine to get them very close, and its not gonna make the trip out to the tips! LOL
Well, its -27 C here thismorning, so its back to the building table for me!
Have a good one and enjoy your next flight!
