RCU Forums - View Single Post - Seagull Models Extra 300S .60 Questions
Old 02-15-2004 | 04:27 PM
  #56
Astro_hog's Avatar
Astro_hog
Default RE: RE: Seagull Models <span class=
I just finished moving the cg across.
I calculate it to be 10.3cm at the fuse...
It seems to be following the main spar and works when you run a string line from tip to tip...
Thats the number I am using for a normal set up....
