RE: Motor Modifications
You can reverse the carb assembly on a Saito by undoing the two screws that holds the assembly to he backplate, carefully revolving it and remounting. There is an 'O' ring in the housing of the tube you are revolving, so be careful not to damage or lose it.
-David C.
