RE: RE: Seagull Models <span class=
Thanks Astro! I'm using a 13x6 APC prop, and yes, I will be changing the fuel tank very soon!
I didn't measure my CG at the fuse sides, but after I balanced it at the wingtips, I balanced it at the same part of the spar next to the fuselage sides.....if you follow the spar, which is straight, you'll be OK.
