Finished
Well she is done!!!
Patty weighs in at 16.7 lbs. dry
Taurus TS42 engine
Zinger Pro 22x8 prop turning 6800 rpm's
Fiber optic kill switch
Duralite Batteries 2000mah two cell ignition with 5.1v regulator, Plane has two 1900mah four cell packs with 6v regulators and fail safe switches.
Hitec digital servos 5645's on the Rudder and Elevator. 5625's on the Ailerons. Standard Futaba servo for throttle.
Hayes 16oz tank mounted on the wing tube.
Graphtec main and tail gear with no wheelpants.
Futaba R138DP PCM Rx.
Due to high winds 15 gusting to 20 the Maiden flight was postponed till next week. Thanks everyone for running a good thread and advice.
Pete
