RE: Chip Hyde's Cap-X - Building & Flying
Zonk,
Did you CA the elevator or use Epoxy? The manual says CA. I've never CA'd an elevator in, but I might try it this time because the fit is so tight and there is so much surface area.
csteve - I see you have a large gap around the elevator... Don't know why. I assume your using epoxy. Thanks for the info on the deals connectors. I did use heat shrink around each lead.
