RE: Chip Hyde's Cap-X - Building & Flying
Yeah, Goin Vert, I did use Epoxy on the Stab/Elev. I had good alignment just a sloppy fit. I used CA on a Funtana one time and it broke loose, but then again, there wasn't nearly the amount of contact between the two parts as there is in this case. (or at least should be) I got everything lined up and put it together with some 30 minute Epoxy so I hope everything works out.
Zonk, thanks for the tip on the wheel pants. I will be trying that one!
Tell ya what guys, overall, I am very impressed with this model! It's the kittens britches so to speak! Well, time to go hit it again.
