ORIGINAL: Spindizzy
Bill
I built a co-axial gyro from a converted fixed wing fuselage. I used the same hub arrangement as Al's but used proper sectioned blades instead of the flat paddle type. The blades had an incidence of around +1 degrees and self started by angling them forward 45 degrees before the take-off run. It flew superbly and both rotors appeared to be rotating the same. In fact it flew so well that i am currently building a small version using an .09 size engine. Maybe my model was just a fluke and this new one I am building will have the 'lazy' rotor. We will see !!
Sean
Congratulations, Sean!! Interesting that you can get "self starting" with +1 degree of incidence. In any event you have accomplished a significant result!
BTW are you aware of the Cierva Prize Fly-in to be held early this May in Madrid? I'm sure that your dual rotor and Vee-tailed models would be most welcome there.
Bill
